nrrcnc Posted January 27, 2015 Share Posted January 27, 2015 I am looking for any suggestions for the correct differential to install in my 1983 280zx non turbo. I have installed an LS1 out of a GTO and I am using the six speed transmission also. I am not sure what rear end is currently in he car. How can I tell, and what does anyone recommend to use so ruin the drivetrain?? I was going to modify the underneath and use the GTO rear end but then I have to drop another $1500 for custom axles. Any help would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
blake culp Posted January 27, 2015 Share Posted January 27, 2015 Depending on the use of the car I wouldn't be afraid to use the r-200 already in the car, if your ZX had a 5spd transmission your most likely have 3.90 gearing which is slightly higher than the 3.46 that came with the GTO. If you're only using it on the street and light drag strip duty I'd bet you will never break the rear end currently in your car. If you want to keep near stock gearing, most automatic zx's and turbo cars came with 3.54 gearing. Find one and swap it out. A little searching on google will show the difference between the nissan r180 and r200 rears, also what to check for regarding the gear ratios. I would not pay to have the GTO rear modified, they break in GTO's and popular swaps are for independent Ford 9" and 8.8" setups. Quote Link to comment Share on other sites More sharing options...
nrrcnc Posted January 28, 2015 Author Share Posted January 28, 2015 Thank you very much! Saved me some money for sure. But how don't know if it's an R200? It's a non turbo 1983 ZX 5 speed. Thx again for the help! Quote Link to comment Share on other sites More sharing options...
blake culp Posted January 29, 2015 Share Posted January 29, 2015 99% probability it is a r200. As for telling the difference, it took me .01 seconds to do a google search.... http://www.google.com/images?client=safari&rls=en&q=r180+vs+r200&oe=UTF-8&hl=en&sa=X&oi=image_result_group&ei=GbfJVOfOE4GNyAT60ILABw&ved=0CBQQsAQ Quote Link to comment Share on other sites More sharing options...
Boy from Oz Posted January 29, 2015 Share Posted January 29, 2015 The axles are under $300. The GTO uses what are commonly referred to as Porsche 930 CVs. They are used on a wide range of cars and are very common in off-road buggies. http://www.ebay.com.au/itm/930-28-SPLINE-AXLES-22-23-24-25-26-27-28-LONG-/290485456372?pt=Motors_Car_Truck_Parts_Accessories&hash=item43a2484df4 Also see: http://www.viczcar.com/forum/index.php/topic,14440.0.html Quote Link to comment Share on other sites More sharing options...
CHEQUERED FLAG JOE Posted February 27, 2015 Share Posted February 27, 2015 Hi Guys I've got some billet chromoly stub axles you might need. For your LS project. modern-motorsports.com Joe Quote Link to comment Share on other sites More sharing options...
