Ron240zxt Posted January 17, 2002 Share Posted January 17, 2002 Hello all, Well i need some assistance or information on setting up a reliable timing curve for a lets say 8.9 to 1 compression engine running 20psi of boost. Also any one have a idea what psi the factory RX7 550cc injectors run at? ie is it 32lb with the vacumm port unplugged off the regulator... Thanks for the help. Ron 240zxt Quote Link to comment Share on other sites More sharing options...
Scottie-GNZ Posted January 18, 2002 Share Posted January 18, 2002 Ron, I do not think anyone can build you ignition maps that will be just right for your setup. I suggest you follow my guideline to establish a baseline, then adjust from there. Here goes. VERY IMPORTANT, to properly set up the ignition for boost, you have to build 2 maps, IGN and IGN RET/MANPRESS. IGN sets the initial timing and advance and IGN RET/MANPRESS (ignition retard based on manifold pressure) retards timing based on boost. The combination of the values of the 2 maps is the total ignition. First, build a IGN map with 20*BTDC at idle and ramp it up to 34* at 3400RPMs (full advance), then take that 34* value all the way to redline. Next build an IGN RET map that starts to retard the timing at say 2-3# boost and ramp it up to retard 10* at 15# boost so that the total timing is 24* at 15# boost. Since you are just about guaranteed to be running over 3400RPMs at 15# boost, you would then have 34* advance minus 10* retard for a total of 24* @ 15#. If you have a 2-bar MAP sensor, that is as far as you can go and any boost beyond 15# will have 24* timing. If you have a 3-bar sensor, continue pulling timing at 1* / 1# which would net a total timing of 19* at 20# boost. Remember, this is a baseline and you need to monitor and tune from that point, especially if you intend to run 20# on pump gas. Remember Morgan? He started with that baseline and he ended up adding more timing and the car responded well. Hope I did not make it confusing. This is for all who will eventually be programming their SDS. I am intentionally not providing a full map because I think it is a good idea to understand the principle so you can build your own and more important, know how and why adjustments need to be made. Hope I am not coming across as the "school-mom" . As for the FP, I am not sure so you might want to ask on a RX-7 board or maybe BLKMGK knows. Typically, OEMs are set at 36# and aftermarkets at 43#. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted January 18, 2002 Share Posted January 18, 2002 just how hard is it to tune with the SDS system? i am thinking about eventually swapping the 2.3T motor out of my t-bird and into a pinto as my daily driver. and i was thinking it would make it a LOT easier to do the swap with that system. i want to run the 3ME-F unit. nice to be able to chuck the dizzy out of the picture. oh, speaking of my 2.3T, i just had a VERY nice find for it. i went to a local pic-n-pull and scored a t3 turbo (my car model year came with a smaller IHI) for 20 bucks . i just have to go get it tomorrow, i tried to take it yesterday but it was so cold that my hands went numb and refused to obey me. thats when i decided i should get back to my car, turn the heater on full blast, wait till i could move my hands again, drive home and come back on a warmer day . Quote Link to comment Share on other sites More sharing options...
Scottie-GNZ Posted January 22, 2002 Share Posted January 22, 2002 Hey Ron, did my post help? Quote Link to comment Share on other sites More sharing options...
Ron240zxt Posted January 23, 2002 Author Share Posted January 23, 2002 Hey Scottie, Yes Vary much help full. I wrote down what im going to do just havent got around to inputing it yet. Maybe Thursday im off. I was so disappointed when she started detinating once again Thanks for the Help Ron Quote Link to comment Share on other sites More sharing options...
Scottie-GNZ Posted January 23, 2002 Share Posted January 23, 2002 Did you see the inj duty cycle when it was detonating? Certainly could be the timing, but you want to make sure the DC was not out of whack. Quote Link to comment Share on other sites More sharing options...
Ron240zxt Posted January 24, 2002 Author Share Posted January 24, 2002 Unfortunally i wasnt able to look at the duty cycle. I was to upset when it detonated. to even try it again... tommorows another day. Thanks for all the help Ron Quote Link to comment Share on other sites More sharing options...
