dexter72 Posted May 9, 2015 Share Posted May 9, 2015 I have an ancient version Megatune, MS2 v3 2.68 code. Bought from DIY.com 8 years ago. Was running my L28nat setup. Swapped a 2j-Nat in my car. Edis6 36-1 trigger wheel, vr sensor now. But No Tach Signal to MS2. I have spark at the plugs, I can run the engine on starting fluid. Looking for some assistance on trying to get a Tach signal. Shielded wire going to Ms2 from the Edis Module. Adjusted the trim pots, still nothing. Attached an MSQ Hopefully it opens up. Possible settings issue??.. Thanks for the assistance in Advance.. megasquirt201505031902.zip Quote Link to comment Share on other sites More sharing options...
Matt Cramer Posted May 15, 2015 Share Posted May 15, 2015 (edited) Try changing the next pulse tolerances to 50%. Also, can you get RPM on a Stim? Edited May 15, 2015 by Matt Cramer Quote Link to comment Share on other sites More sharing options...
