Aftermarket A/C cutoff switch
Guest gprix1
Rick, save yourself a few bucks (lots actually) and look at the pedal of a automatic equiped early Z car. Mine has a microswitch that is operated at full throttle I'm assuming Nissan did that for kick down. Anyway, using one of those switches and a $6 12v 30 amp relay from radio shack will give you the same deal for a savings of at least 60-65 bucks. ;)
You do need to get the relay that has 5 pins so it can disconnect when energized.
Regards,
Lone
