theBrit Posted July 6, 2015 Share Posted July 6, 2015 Hi all I have the one of the original MM cobra 13" conversions and started to wonder if I could improve the pedal feel with a change of pad material, there are a range of options for this set up based on the 2004 mustang. This is the data that set me thinking http://www.hawkperformance.com/compound-graph it looks like HP+ should just be plain better than OEM, with a downside on dust, noise etc I expect. I'd like to add a little bite when cold / warm - no track time. I have the 240sx rear rotors and all the right proportioning valve, master cylinder modifications etc and I think the pedal feel could be better, its easy to lock the fronts without getting the feed back its about to happen. I spent a lot of time testing and adjusting the proportioning valve until the rears never locked first when I first set this up a few years ago so I assume the bias is about as good as it can be for my set up. But before I start fiddling again - does any one know which pads Ross used to supply, I could not find any details written on the pads themselves so I dont know if I am starting from some generic OEM pad or a performance pad. Quote Link to comment Share on other sites More sharing options...
