Guest Anonymous Posted August 22, 2002 Share Posted August 22, 2002 I was just wondering if any of you guys know about gearboxes for FJ20's or CA20 engines I have a gazelle sitting here with a CA20 engine and 5speed box behind it (all stock) I was thinking of putting a FJ20 into it but dont know if I can use the same gearbox or not. Just courious, I know its not a Z but you guys realy seem to know nissan so I thought I could ask. Thanks. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted August 23, 2002 Share Posted August 23, 2002 *bump* comeon someone gotta know something here you all so good with nissans Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted November 29, 2002 Share Posted November 29, 2002 i drive ca20 gazelle, and have the factory manual/book , which also includes the fj20de (non-turbo), the part number for the gearboxes is the same and the clutch is the same, the only difference is the gear ratios, i believe it is the same box. Good luck with your conversion, i have looked into this conversion myself but never found a s12 fj20de 1/2 cut to use. Keep posting your results id be intersted how you go and how expensive it is!!!!! ps. might be an idea to pick up a copy of the factory manual yourself!! Quote Link to comment Share on other sites More sharing options...
