wiring specialties Posted August 7, 2015 Share Posted August 7, 2015 (edited) Our popular 2JZGTE Pro Series wiring harness is back in stock and ready to be shipped. This harness sold very quickly after our last production run so act fast and get yours now before they sell out again! Prices start at just $849. This harness is designed with the highest quality standards in mind and acts as a direct drop in, plug and play wiring solution for a variety of applications. It also supports many ECU, injector and MAFS types and comes built in with quick disconnects to allow you to easily change your setup. Pro Series Harness Features: Plug and play No cores or additional wiring required Point to Point continuity tested on every wire Constructed using OEM connectors and seals Made with high temp TXL wire (-40C to +125C operating temperature) with adhesive shrink tubing Wrapped in lightweight nylon loom with -94C to +257C operating temperature Improved grounds Quick disconnect MAFS/AEM/Haltech/PFC Speed density extensions (change from MAFS TO AEM/Haltech in seconds) Coil and knock sensor sub-harnesses Transmission harness with reverse and speed sensor wiring Alternator charge cable Retains factory A/C, fans, speedometer, tachometer, engine temperature gauge, oil pressure sensor, alternator charge light, reverse lights and wipers Edited August 7, 2015 by wiring specialties Quote Link to comment Share on other sites More sharing options...
