Need detailed instructions on engine swap
If you are going to be just using the motor and not the fuel injection stuff from the 280Z, it should be a bolt in. If you swapping in the fuel injection as well, then get EVERYTHING from the 280Z donor car.
My advice is to buy a Haynes manual and go from there. Also, a factory service manual helps too.
David
