dpwong Posted October 11, 2002 Share Posted October 11, 2002 Hi, Any one using Aurora V8 4.0L engine ? Can it be RWD? Bell housing bolt pattern Similarities? Thanks dpwong Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 22, 2002 Share Posted December 22, 2002 Is it true that using the Aurora mill is tough since GM has kept the control module, CPU, etc. under wraps? My street machine bud's recommend FORD DOHC 4.5's due to open engineering archetechure. From what I hear most who want a DOHC engines stay away from Aurora's. However, they really look like a dynamite engine. Quote Link to comment Share on other sites More sharing options...
Guest Dan0myte Posted December 23, 2002 Share Posted December 23, 2002 It's the engine used in the Shelby Series 1. Do the Z convertible kit, put the Aurora V8 in it and you've got your own Series 1 at a $50,000 discount. Quote Link to comment Share on other sites More sharing options...
Guest Tht1KSguy Posted February 6, 2003 Share Posted February 6, 2003 The Aurora 4.0 is very similar to the Northstar 4.6L I know it has a smaller bore, not sure about stroke. The T5 from '93+ V6 Fbody's bolts up directly as does the overdrive auto from the same cars and the 700R4 from any 2.8L S-10. The main difficulty would be switching to a remote water pump since in the rear drive position the water pump would be against the firewall. Also you can't use the stock computer. Chrfab.com makes a Commander 950 system that plugs into the Northstar for $1300 I'd guess it would work the same for the 4.0L. I'm currently in the process of buying JAMIE T's Northstar to drop into a Fiero. Now I just need to come up w/ an '88GT. Hope that helps. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted February 22, 2003 Share Posted February 22, 2003 I guess this isn't really useful since you don't need a whole car, but... My boss will be putting his 98 Aurora up on e-bay this weekend. He says he's only looking to get $3500 or so. It has 130k on it, and he's getting rid of it because: It had a persistent coolant leak that his mechanic says is probably due to a leaking head gasket that is causing way too much pressure in the cooling system. It supposedly will need a new evaporator core soon...? I have no more details. I'll post the auction link when I get it. Quote Link to comment Share on other sites More sharing options...
Guest Azel Posted March 10, 2003 Share Posted March 10, 2003 I wonder how light this motor is? The Northstar's an extremely light DOHC V8 and is more than a half liter larger! Quote Link to comment Share on other sites More sharing options...
Guest Tht1KSguy Posted March 10, 2003 Share Posted March 10, 2003 405lbs give or take. That's what I've read anyway. Aluminum block and heads, steel internals and a magnesium or plastic intake depending on year. I would assume the 4.0 and 4.6 weigh virtually the same since only internals are changed. Quote Link to comment Share on other sites More sharing options...
