what fuses to use?
notothisrealm
So, I wired up this fuse block on my 71 240z V8 and am trying to figure out what size fuses to use for each wire. The one on the left is coming from the alternator. The one in the middle is going to the white w/red stripe wire that went to the old ammeter. And the one on the right is a blue wire going to the fuel pump relay.
For the fuel pump, use what Holley recommends. The early Z does not have any fuse or fusible link on the alternator output. There is one fusible link between the battery and the whole car, including the alternator. You can add a fuse or fusible link if you want, it can't hurt. You should have a fusible link between the battery and the car as well. The fuse you have in the ammeter lead is not necessary, especially if you have the other two.
