randy 77zt Posted August 26, 2000 Share Posted August 26, 2000 if you are building a z for any scca or nasa racing be sure to check the rules before buying a fuel cell.none of the cells in summit are legal for scca.the only cell usually spotted in a scca car is a fuel safe. Quote Link to comment Share on other sites More sharing options...
BLKMGK Posted August 27, 2000 Share Posted August 27, 2000 What exactly do the rules say? I think that they require a bladder and a container - yes? If so check out some of the roundy round circle track cells. I thumbed through a catalog and while I'm not sure on sumping and sizing they looked to contain bladders and containers - they also didn't cost as much as I think the Fuel Safe cells do. I used a Triangle aluminum cell with foam in it for mine. It's rigidly mounted and should pass NHRA type tech but I'm fairly sure it won't pass SCCA. I still need to vent it with a roll-over valve. The one sold by Summit and Jegs righ tnext to the fuel cells does NOT fit my cells return. It's supposed to be a 3/8ths fitting - NOT by my ruler it's not! The roundy round guys have some inline rollovers meant for remote mounting that are like $16 - I'm going for one of those instead... P.S. How many of those battery boxes do you think would pass real tech? I'm pretty sure most wouldn't in a hatchback. They are supposed to be sealedvented to the outside and I'm pretty sure require a metal container that must be bolted solidly. summit sells an aluminum one that appears to fit the bill - I've got one and it looks decent... Quote Link to comment Share on other sites More sharing options...
Guest Locutus Posted August 27, 2000 Share Posted August 27, 2000 My stock truck has an inline one that would fit anywhere, I have it right at the tank but my tank has lots of room since the bed is gutted, But I would seriously consider an inline one they do work, I rolled my truck and no gas spilled out. Mike Quote Link to comment Share on other sites More sharing options...
BLKMGK Posted September 1, 2000 Share Posted September 1, 2000 Thanks Mike! I tracked down a roundy round parts place and got one for all of $6! Figured out how that vapor canister works I think any may use it too. As an aside - took the car to the chassis shop to talk about getting the main hoop moved - they'll do it. Ran out of gas on the way over but had carried a can with 2 gallons in it with me (whew). After I got a date from them to get the car done I hit the gas station for a full fill since the chassis guys said it didn't have to be empty this time. My "10 gallon" Triangle tank - with close to 2 gallons already in it - took nearly 10gallons and I didn't even have gas up over the foam! This puppy can probably hold like 12+gallons, maybe more if I yanked some of the foam out. This is a big relief for me as I was worried it would be too small at only 10gallons... Quote Link to comment Share on other sites More sharing options...
