clint78z Posted September 11, 2000 Share Posted September 11, 2000 Yes that is what I needed to know, I hope it is not the ECU . A ship back would a PITA, probably something I am missing I hear the ECU's are very reliable . Quote Link to comment Share on other sites More sharing options...
clint78z Posted September 12, 2000 Author Share Posted September 12, 2000 I have my DFI hooked up and just about all sensors are go . The fuel pump and 02 sensor power wire from ECU is not providing power output to my relay . FastFrog did the DFI pump come on as soon as you turned the key to on ?? Quote Link to comment Share on other sites More sharing options...
Guest Fast Frog Posted September 12, 2000 Share Posted September 12, 2000 Clint: Yes, the fuel pump should "buzz" when the ignition key is in the on position. I'm not sure I can help you with the O2 sensor, but I had the Fuel injection relay burn out on me 3 yrs ago. Engine would turn over but not start. This relay is part of the DFI harness. My setup had the FI relay just under the passenger side dash. I purchased a Bosch type relay for about $35. Hpoe this helps (If I understand your question right!). [This message has been edited by Fast Frog (edited September 11, 2000).] Quote Link to comment Share on other sites More sharing options...
