Accel DFI question
clint78z
Guest Fast Frog
Clint:
Yes, the fuel pump should "buzz" when the ignition key is in the on position. I'm not sure I can help you with the O2 sensor, but I had the Fuel injection relay burn out on me 3 yrs ago. Engine would turn over but not start. This relay is part of the DFI harness. My setup had the FI relay just under the passenger side dash. I purchased a Bosch type relay for about $35.
Hpoe this helps (If I understand your question right!).
[This message has been edited by Fast Frog (edited September 11, 2000).]
