Guest LoFlyingZ Posted December 21, 2000 Share Posted December 21, 2000 For the sds system which style injectors are used or can you specify? If I understand, for performance the Peak and Hold are desirable, but for most applications saturated work fine. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 21, 2000 Share Posted December 21, 2000 SDS will use either. Whichever is the low resistance requires dropping resistors in the injector harness to lower the current. They sell a resistor pack, but any high wattage resistors in the 8-10 ohm range will work. ------------------ Morgan http://z31.com/~morgan/s30 http://carfiche.com Quote Link to comment Share on other sites More sharing options...
