Guest Anonymous Posted December 28, 2000 Share Posted December 28, 2000 Morgan, I don't think any baffels would be necessary. I don't have any in my tank but then again I don't think it would hurt and may as you say, prevent some air bubbles at the outlet. Mark Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 28, 2000 Share Posted December 28, 2000 Any suggestions on surge tanks? I picked up some scrap aluminum wednesday and cut out my surge tank. It's round, 4 inch diameter(Maybe 5 inch, didn't mesure), and about 30cm or so tall. I tapered one end at roughly a 45 degree angle, it will be the bottom and the pickup fitting will be an inch or so from the bottom on the tubing. The other 3 fittings will be horizontal at the top of the tank. You think any baffling will be necessary? Perhaps a horizontal plate with a hole in the middle to prevent fuel from sloshing around and make it harder for any bubbles to get down to the pick up tube? ------------------ Morgan http://z31.com/~morgan/s30 http://carfiche.com Quote Link to comment Share on other sites More sharing options...
