Guest zfan Posted January 9, 2001 Share Posted January 9, 2001 IVE DECIDED TO GO THE ELECTRIC FUEL PUMP, 3/8 LINE PLUMBED FROM THE BOTTOM OF THE STOCK GAS TANK. WHAT TYPE OF LINE SHOULD I USE IS ONE ANY BETTER THAN THE OTHER? THOUGHT ABOUT RUNNING 3/8 ALUMINUM WHERE THE STOCK SETUP IS AND USE THE 5/16 FOR RETURN. FROM TANK TO FILTER TO PUMP I WOULD USE RUBBER FUEL LINE AND UP FRONT FROM FRAME RAIL TO REGULATOR I WOULD ALSO USE RUBBER FUEL LINE. THE STRAIGHT RUN UNDER CAR I WOULD USE SOLID FUEL LINE. GOOD IDEA OR BAD IDEA, ANY COMMENTS OR SUGGESTIONS. Z/FAN..MIKE Quote Link to comment Share on other sites More sharing options...
