Arif Posted December 28, 2000 Share Posted December 28, 2000 Morgan, I THINK they shipped the bosch type water sensor. It did fit without any problems. I went with the 2 bar map sensor. I am using a t3/t4e turbo and expect to run max boost at 17psi(about 350hp). I went with the 2 bar because it really doesn't take more than 350hp to get into the 11s. Which is what I was aiming for with my set up. Carlos (sells the sds) also told me the 3 bar was better suited for race applications, these two circumstances are the reason I went with the 2 bar. I haven't set my boost that high because I am still breaking in the engine. So only time will wether my t3/t4 will generate 350hp at 17psi. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 28, 2000 Share Posted December 28, 2000 Which water temp sensor did you get? The pipe thread one or the "bosch metric" one? Does the "bosch metric" water temp sensor fit into an existing hole in the thermostat housing? If not did you just drill a hole in the thermostat housing and cut pipe threads in it and use the pipe threaded sensor? The 'bosch' sensor looks like it'll fit in an existing hole, but I wanna be sure before I order it. And will a stock nissan water temp sensor work? They're all just thermisistors right? All thermisistors are the same aren't they? Also, any status on the sds deal? It's practically early janurary now! I'm holding off on picking up my engine because I don't have the sds yet - hope they don't sell my engine before I get it! And someone other than scottie answer - did you use the 2 or 3 bar map sensor? ------------------ Morgan http://z31.com/~morgan/s30 http://carfiche.com Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted January 4, 2001 Share Posted January 4, 2001 It fit in the thermostat housing I assume you mean, right? The stock holes aren't tapered pipe thread holes, or are they? ------------------ Morgan http://z31.com/~morgan/s30 http://carfiche.com Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted January 11, 2001 Share Posted January 11, 2001 Any update on this? Which one(If either) of the sds water temp sensors fit into the stock l28t thermostat housing? Also, any status on the sds deal? I am rapidly approaching needing mine, can't wait too much longer. Picking my turbo up monday! ------------------ Morgan http://z31.com/~morgan/s30 http://carfiche.com Quote Link to comment Share on other sites More sharing options...
Guest scca Posted January 11, 2001 Share Posted January 11, 2001 i was planning on starting it up again in over the weekend. i'm on the work computer and all my emails are on the laptop.. you can always be the first! Mike Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted January 11, 2001 Share Posted January 11, 2001 My schedule has been pushed back like you wouldn't believe! One thing after another than I have no control over I will be needing it soon, and am going to wait as long as possible to save an extra 10%. Count me in ASAP if you ever get 10 people. ------------------ Morgan http://z31.com/~morgan/s30 http://carfiche.com Quote Link to comment Share on other sites More sharing options...
Scottie-GNZ Posted January 11, 2001 Share Posted January 11, 2001 Spoke to Carlos again recently and he is willing to offer 15% to a smaller group purchase of 5. ------------------ Scottie 71 240GN-Z Scottie's GNZ Quote Link to comment Share on other sites More sharing options...
Guest scca Posted January 11, 2001 Share Posted January 11, 2001 Scottie i dont remember getting a email back from him though- the previous arrangement you mentioned with him is a possibility. there "appears" to be 10 in my email list of serious people.. ------------------ Mike mike@fonebooth.com http://www.fonebooth.com/brakes.html raceparts and brake upgrades. Quote Link to comment Share on other sites More sharing options...
