Guest Anonymous Posted January 11, 2001 Share Posted January 11, 2001 How come I can't get an answer to this? Which sds water temp sensor fits in a stock hole on a l28t thermostat housing? I've been told one does, but which sensor was it? The bosch one, or the pipe threaded one? ------------------ Morgan http://z31.com/~morgan/s30 http://carfiche.com Quote Link to comment Share on other sites More sharing options...
Arif Posted January 12, 2001 Share Posted January 12, 2001 Morgan, I figured someone who knew the answer would have replied by now. Contact Carlos at Racetech (321) 229-6140. When I ordered mine I told him what type of car I had and he sent the correct size water sensor. ------------------ http://communities.msn.com/TurboZ Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted January 12, 2001 Share Posted January 12, 2001 Well, did it have pipe threads or did it have normal straight threads? Will carlos give me the discount? Or would I need to order direct to get the 10% off by mentioning zcar.com? ------------------ Morgan http://z31.com/~morgan/s30 http://carfiche.com Quote Link to comment Share on other sites More sharing options...
Scottie-GNZ Posted January 12, 2001 Share Posted January 12, 2001 You said you wanted someone else to answer so I did not respond. I used all NPT and did the appropriate tapping. I used the therm housing from a later model that had all the crap on it and plugged what I did not use. SDS will give zcar.com members the standard 10%. Carlos will give 15% to a small group of 5 or 20% to the larger group purchase. ------------------ Scottie 71 240GN-Z Scottie's GNZ Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted January 12, 2001 Share Posted January 12, 2001 I was asking about something else when I said someone other than you reply So... the pipe thread water temp sensor doesn't fit in an existing hole on the thermostat housing? The air temp sensor.... I assume some of those tapped bosses on the manifold are 3/8 npt threads right? I'd just rather use existing holes than drill new ones if possible is all. And the 15% carlos discount..... are there 4 other people who will join me? If not I'm gonna hafta order soon..... ------------------ Morgan http://z31.com/~morgan/s30 http://carfiche.com Quote Link to comment Share on other sites More sharing options...
