webers
Guest Anonymous
Guest Anonymous
webers suck. I finally figured out what was wrong with my car today..... I changed the blown out manifold gasket to no avail. So I disassembled the frontmost carb since the front 2 plugs were badly fouled....
The internal throttle return spring was broken - the loop on the end broke off, the spring fell down into the spring/accelerator pump lever, and was jammed in the lever, preventing the throttle from closing fully.
I bent a new loop onto the end of the spring and all was fine after a few speed runs to clean out the plugs and such. Sweet!
I have 30mm venturis..... anyone have a set of larger 40dcoe venturis for sale by any chance?
Morgan
http://z31.com/~morgan/s30
http://carfiche.com
Morgan, do you have the dual downdraft Webers or the side draft kind? I have dual downdrafts, but do not know how big they are. I would possibly sell them to you, but need to understand what you are looking for (I don't know much about Webers).
David
