LS2/3 C6 Corvette Oil pan on 4.8/5.3L -- Dipstick issues
Hey guys,
I've swapped a C6 oil pan onto my LSX swap, I use to have a modified truck pan but wanted more ground clearance.
I got the correct pickup and windage tray from the seller, but no dipstick, on my OEM stick the oil level reads about an inch past the full mark of the stock dipstick. Ive put exactly 5.5 Quarts into the pan.
Is this reading normal with the incorrect dipstick and tube? Id assumed the oil level would be constant to the block regardless of what pans installed.  If I can get a consistent reading I was hoping to simply mart the dipstick at the current level.
Thanks,
