Guest 1z2c Posted March 13, 2001 Share Posted March 13, 2001 I don't know if this is the right place to post.But here is my question.I have a 350 - 375HP in my Z.(JUST GETTING STARTED) Will a stock Chevy starter be good enough to use.Or would I be better of buying a high torque starter.Like the small racing ones. Quote Link to comment Share on other sites More sharing options...
Guest zfan Posted March 14, 2001 Share Posted March 14, 2001 Im running around 400 hp and use a stock chevy starter with no problems...Knock on wood! Mike Quote Link to comment Share on other sites More sharing options...
Guest 1z2c Posted March 14, 2001 Share Posted March 14, 2001 Thanks for the info ZFAN.i was going to use a stock starter, bot found out today that my block has the inline starter bolt holes.And I put on a 168 tooth flywheel.The inline bolt patter does not take a 168 tooth flywheel it takes a 153 tooth flywheel.So when I went to buy a stock starter they gave me the starter that has the off set bolt pattern.So I have to go with a mini starter that has both bolt patterns it has both bolt patterns.It cost more but I didn't want to pull my motor out and change the flywheel. Thanks Again for your advise ! Quote Link to comment Share on other sites More sharing options...
