Guest Tom Scala Posted May 14, 2001 Share Posted May 14, 2001 Does anyone happen to know which pin on a stock 78 ECU wire harness is the power lead? I was thinking of using it to run the SDS ECU. I am also thinking of using the factory relay & power lead for the ballast resistor to run my injector harness. Has anyone done it this way or is there a circuit in the fuse box that is hot in start & run on a 78? They all seem to be either battery or accesory circuits & not hot with the key in the start position. Thanks. Quote Link to comment Share on other sites More sharing options...
Scottie-GNZ Posted May 15, 2001 Share Posted May 15, 2001 Tom, Cannot tell you which lead you need in a 78, but when I did mine, I just got out the old test light and tested every circuit until I found one that was hot while cranking. I then tapped into that wire and used it to trigger relays which had all new hot leads off the alternator for the ECM, injector driver and coilpack. Quote Link to comment Share on other sites More sharing options...
Kennysgreen280zt Posted June 6, 2001 Share Posted June 6, 2001 i used the positive lead from the coil as i didnt need it any more. got it fired up last night!!!! hope this helps ya ~Kenny Quote Link to comment Share on other sites More sharing options...
