Guest zfan Posted June 22, 2001 Share Posted June 22, 2001 Ok Im sick in friggin tired of replacing spark plug wires every few months! I have tried several brands of wires and have used taylor heat boots, even double boots and still frying the f-----g wires!! Anyone else have this problem? The wires tend to fry around the boot base wear wire goes in. Today at work in the parking garage a friend was checking out my car and commented as it is pretty dark in there, check out the spark around the plugs! All said and done I found three total out of eight that were sparking around heat boot covers. Im using sanderson block huggers with ceramic coating and still. They are a tight fit, very close to plug wires. Im thinking of just buying Accel wires thru summit or jegs as they are cheap, 20 bucks a set. If Im going to fry wires left and right I might as well not go broke on it! Mike Quote Link to comment Share on other sites More sharing options...
Kevin Shasteen Posted June 22, 2001 Share Posted June 22, 2001 Have you checked into Jacobs Electronics. Dont they sell a 100% silicone wire. Also, if memory serves me correctly-he also sells the same wire for R.V.'s where the boots are "Porcelin" for those that keep burning boots...I believe thse porcelin wires ares suppose to be lifetime warranty? I bought a set of his wires about 10 years ago (just the regular 100% silicone wires) for an Olds Cutlass I used to own, & their boots were vulcanized. I've since bought & sold three different Cutlasses. Each time I sell an Olds Cutlass-I keep those wires & save them for the next Olds V8: I thought they were real quality wires-so the wires w/the porcelin boots should be eqaul quality..unless someon else knows otherwise(?). Something to check into anways. Kevin, (Yea,Still an Inliner) Quote Link to comment Share on other sites More sharing options...
BLKMGK Posted June 22, 2001 Share Posted June 22, 2001 Careful - if the porcelin contacs the header the whole thing heats up and the wire inside "fries". I learned this from someone who had gone through the experience... You want to maintain at least a little airgap if possible. Those suckers are straight boot only too I think and NOT cheap. Correction - they DO come in 90degree boots as well. I think I'll try a regular MSD set first and then see how bad they burn etc. I'll be running straight plugs... [ June 22, 2001: Message edited by: BLKMGK ] Quote Link to comment Share on other sites More sharing options...
Guest Fast Frog Posted June 22, 2001 Share Posted June 22, 2001 Mike: Get a set of Extreme 9000 plug wires from JEGS or Summit or where ever! They have a special flex boot that is very heat resistant. Also, slightly dimple(1/8")-on each header-on each end runner near the two center plugs. This gives a little more room for the boot. I had the same problem several yrs ago with boots splitting and the spark arching onto the headers. This was my solution! Rick Quote Link to comment Share on other sites More sharing options...
madmanadam Posted June 27, 2001 Share Posted June 27, 2001 I'm using the Accel 300+ wires from Summit Racing, R&M wire looms and Block hugger headers. I used zip ties to hold them away from the exhuast. So far no problems Adam Quote Link to comment Share on other sites More sharing options...
madmanadam Posted June 27, 2001 Share Posted June 27, 2001 Well looks like the pic didnt show, heres a link to what mine look like. http://www.geocities.com/MotorCity/Downs/9364/Z-car/3-18-1a.jpg Adam Quote Link to comment Share on other sites More sharing options...
