Quick Question
Guest Locutus
If you use the JTR setup you have to use an electric fuel pump because the mechanical one will not fit with the set back plates bolted to the engine.
Mike
[ July 04, 2001: Message edited by: Locutus ]
Ah, so that's the reason! My motor is in the Scarab position now. Might convert to JTR later, but there are other things that need attention first. Thanks!
