Injectors leaking
Just found out I have 3 injectors leaking. They are the stock lt-1 24# injectors. I can get a set for $280 locally (from a reputable speed shop) but the are ford injectors. I don't have a problem with ford, just curious if this is a common swap. Thanks Mark
Guest Locutus
They aren't ford injectors persay. Ford, GM, and alot of others use bocsh(sp) injectors, and are interchangable. I believe there are a few other brands as well that are considered acceptable.
Mike
