dpuma8 Posted September 19, 2016 Share Posted September 19, 2016 Hi everyone, I finally got my engine back from the builder after 3.5 years and I want to make sure that the specs on it seem okay. It was a hassle and in the end, the builder forgot to put the oil pump spindle in so I would like some input on a few mods he made. F54 block with L28et ITM pistons with standard bore Stage 2 port work on P90 head, machined for double springs Isky Lash caps ground to .150" thick Dougherty Racing Cam installed at 106 degrees Schneider springs No 68022 Removed oil bypass in block and plugged hole Ported inlet area under oil filter for better flow Cam Specs Advertised duration 272/272 degrees Valve lift .410"/.410" Centerlines Intake/Exhaust 110/110 degrees Cam timing @ 0.20" Intake opens 26 BTDC degrees Intake closes 66 ABDC degrees Exhaust opens 66 BBDC degrees Exhaust closes 26 ATDC degrees Lobe separation angle 110 Degrees The turbo is a GT3076R .63 and I wanted this car to be streetable with some track use. Can I break in the new engine using a megasquirt tune from the sticky even though cam profiles might be different? Quote Link to comment Share on other sites More sharing options...
grillhands Posted September 24, 2016 Share Posted September 24, 2016 (edited) Start up for 10 min then change oil. Drive 50 miles at half boost and do alot of engine braking. You want the rings to set with your fresh hone. Change oil. Drive 100 miles at the boost you want and really get on it. There is no point on nursing an engine for the brEak in then beating the hell out of it when all the parts already settled in. I've done this numerous times on 50 trim garretts on 1.8t and never had a puff of smoke or blow by. Sorry, I just realized you asked what tune to use to break in the car, not the procedure. Edited September 24, 2016 by grillhands Quote Link to comment Share on other sites More sharing options...
grillhands Posted September 24, 2016 Share Posted September 24, 2016 This is just my 2 cents. I'm sure there are other ways but I think this way is proven and makes the most sense. Quote Link to comment Share on other sites More sharing options...
