Manya Posted September 24, 2016 Share Posted September 24, 2016 Hi all, I've ended up upgrading to an MS3X as I have 1150cc injectors, and I've had a hard time getting them to play nice at low RPM. Also plan on running enthenol at a latter stage. Anyway, I've wired everything up correctly but when I crank the car over, I get an error saying that there is "no cam signal". I have installed jumper JP7 and wired the green wire to the cam input but I'm a bit lost. Do I need to install a pullup resistor for the cam input as well even with JP7 installed? Will adjusting the trim pots on the MS3X be necessary? Any help will be appreciated. Thank you, Quote Link to comment Share on other sites More sharing options...
Matt Cramer Posted September 26, 2016 Share Posted September 26, 2016 What sort of cam sensor are you using? Quote Link to comment Share on other sites More sharing options...
Manya Posted September 26, 2016 Author Share Posted September 26, 2016 Hi Matt, I am using a Nissan cas with the custom trigger wheel as shown in the bottom of the link below. https://www.diyautotune.com/support/tech/hardware/nissan-trigger-disc/ Quote Link to comment Share on other sites More sharing options...
Matt Cramer Posted September 27, 2016 Share Posted September 27, 2016 You may need to adjust the trim pots. Can you post a composite log of what signal you're getting now, and a copy of your MSQ? Quote Link to comment Share on other sites More sharing options...
Manya Posted October 2, 2016 Author Share Posted October 2, 2016 Hi Matt, sorry for the late response. see the link below. https://drive.google.com/open?id=0BzsB9AsvHKEMZWFGLW1UV0h3STQ Thanks Quote Link to comment Share on other sites More sharing options...
Matt Cramer Posted October 3, 2016 Share Posted October 3, 2016 Cam signal looks fine to me. Quote Link to comment Share on other sites More sharing options...
