splintercellsz Posted January 3, 2017 Share Posted January 3, 2017 I am looking to trade my '89 240sx for a Datsun 240z/260z/280z. I do not drift this car, and it is my daily. When not in use it is in my garage. I am looking for a 240z/260z/280z as my father had one before I was born. Sadly, before I was able to see the car, a lady ran a red light and totaled it. I want to honor my dad and build something I have grown up only hearing about. I am located in Clarksville, TN but am willing to travel as long as it isn't some crazy distance. Suspension/drive/wheels: Older dmax adjustable arms. Tension in the front, camber, toe, and caster in the rear. fortune auto 500 coil overs s14 vlsd 5 lug conversion extended lugs up front lower subframe brace front and rear strut tower bars hubcentric rings project mu 7 sided lugnuts Klutch republic sl1 16x9 +12 225/50 kuhmo up front 245/50 falken in the rear engine/transmission: shaved engine bay tubs recently re-sealed s13 blacktop megan motor mounts tomei poncams tomei rocker arm stoppers 550cc Injectors Enthalpy ECU T28 new style megan elbow don't remember the down pipe or test pipe blitz nur-spec cat back 2-piece tucked engine harness with barrel plug in the fire wall brand new p2m 95 amp alternator blitz BOV mkiii supra drift motion intercooler maradyne jetstream 2600 fans larger radiator nismo thermostat silicone hoses isr s14 water outlet j-star intake manifold j-star exhaust manifold wrapped and sealed nismo FPR tucked brake lines tucked clutch line with new master and slave freshly rebuilt transmission excedy hyper single gauges for voltage, fuel pressure, wideband, water temp, oil temp, oil pressure, boost, and vacuum greddy turbo timer oil cooler power steering cooler Interior: Stock Seats tomei shift knob works bell hub NRG 2.3 QR grip royal wood grain wheel NRG harness on drivers side omp harness on passenger side Exterior: OEM metal fenders OEM metal hood Silvia aero bumper dorkidori lower grills ITR lip Dorkidori v1 skirts magic aero valences MoreCollage grill 50/50 turn signals Brick headlights with r32 reflectors, touge factory lenses LED bulbs. clear corners carbon roof wing 50/50 tails square silvia trunk lock No AC/Heat Clean Title Garage Kept Quote Link to comment Share on other sites More sharing options...
