Guest HIGHRPM Posted November 22, 2001 Share Posted November 22, 2001 HI GUYS. A quick question. For the stock ignition system,according to the wiring diagram, the ballast resistor is by-passed during cranking for full battery voltage for good startup but then runs through the ballast resistor for your running igniton, causing it to run on about 9 volts which would create a much longer chargeup time for the coil and hence an inferior spark as compared to systems running a dedicated battery voltage line to the + side of the coil. In my early 260, can I run a dedicated line to the coil without screwing up the ignition box???? 74 early 260 Driver 74 early 260 next project Quote Link to comment Share on other sites More sharing options...
jeromio Posted November 22, 2001 Share Posted November 22, 2001 My experience with running 12 volts to a coil (a regular, non resistor coil) has been coil that lasts about 5-6 months. Quote Link to comment Share on other sites More sharing options...
