Are sr20det gearboxes compatible with Rb20det engines
Yvet
Hi there, was just wondering if anyone had some advice they could give me on sr20det gearboxes and if you can use them with your Rb20det engine. I understand the bell housing clearly would not be interchangeable, but if you kept your Rb20det housing and put it with a sr20det box attached to a rb20det engine. Does this work, its it relatively straight forward or not!?!? Thanks!
 My Z has RB25 with Tilton RB26 clutch and flywheel, and SR20 transmission. I think the input shaft is identical to another. Differences between them are rear housings, the length of the main shaft, and the lid shape of the shift mechanism.
