Will a Vic Jr clear
Guest chevsun
Guest chevsun
Will a Victor Jr. clear the stock hood with the small block id the JTR setback position and a Edel. 750 carb. Is it taller than the RPM intake that I currently run?
Is your RPM an air gap RPM. I have an air gap RPM and it is 24 hundredths of an inch taller than a Victor Junior.
zfan...Mike
PS. If you have any doubts call edlebrock tech line..
They'll all pretty much clear with drop down filters....depends on Vic. Jr. as well. One is a low rise and the other has ~1" spacer built into it. I cleared the lorise version (2975) on my 280ZX with a Mr. Gasket dropdown cleaner base and ~1/8" from top nut (ground flush) to hood. But my 280ZX has a lot less hood clearance than most JTR Z's. With my EFI now in I had to find an offset drop down base (which I did) to clear as air horn was located closer to dizzy than usual carb intake FWIW. Lots of adjustment available in various air cleaner bases/lids/spacers etc.
