HEI Distributor-Need a compatible rev limiter
Guest Rick Johnson
Guest Rick Johnson
Hey guys,
I have an HEI distributor in my Hybrid and I like the look and it works fine for my application. I would like to add a rev limiter but the ones that I see state that they do not work with HEI. Has anyone found and installed a rev limiter to their stock HEI unit and been happy??
Guest digitalz
i installed a holley hp annhialator. i bought the one for hei but ended up making my own harness and triggering the holley box directly from the mag trigger in the distributor.
it has one rev limiter and works great for my apps. it's the one that you set the rev limit on the box with 2 rotary switches.
no need to waste the extra bucks on the hei version, imo. just take out all the electronics from the hei (module, etc) and connect directly to the 2 wires of the mag trigger. to me it's less stuff to go wrong and deal with. so now if you look in the distributor there is none of that stuff under the rotor.
