Guest Anonymous Posted March 14, 2002 Share Posted March 14, 2002 What dist? Point or mag? White wire trigger? Do you have the small red wire hooked up to a keyed source? Take the little red wire that is supposed to go to the key and hook it up to the battery and see if it fires if everything else is hooked up. The keyed source was hooked up to the factory ballast resistor on my Z. The MSD asks you to remove it for the box. I ran around in circles for awhile trying to eliminate the resistor until I figured out the keyed source is at the resistor. Turn the key to "On" and use a test light to see if what you are hooked into is really telling the box to turn on. If not try the red wire straight to the battery terminal for a few seconds and see if it fires... call me at home if you have a problem brother! Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted March 15, 2002 Share Posted March 15, 2002 Jason, email me your number... My wife tossed it DOH! Jumbo30@attbi.com Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted March 16, 2002 Share Posted March 16, 2002 240 0592! be THERE AFTER 5!! Quote Link to comment Share on other sites More sharing options...
