t56 to gen1 sbc clarification
I have read almost every forum about this topic but now im just getting confused :unsure:
I want to mesh a viper spec t56 (2005) to a gen 1 sbc.
I'm replacing a Muncie 4spd.  I will be using the adapter from mcloud since I already spent$$ on a Lakewood scattershield bellhousing.
https://www.summitracing.com/int/parts/mcl-8-207/applications/engine-size/5-7l-350
This adapter will work with the viper tranny?  every forum is about either the lt1 or ls1 tranny.
Also, can I reuse my 168 tooth external balanced flywheel, starter, hyd. throw out bearing and pressure plate?  just need to change the clutch disk to a 26 spline?
The mcloud pilot bushing for the ls1 t56 swap is also used with the viper t56?
I read that the viper input shaft is longer than the ls1.  Does it need to be machined down?
Edited by BillWalsh
