New ignition and gear reduction starter
Guest loveonthebeach
I'm sure my question has probably been answered before, but i can't find it off hand. Anyhow, i'm doing some wiring on one of my cars (engine is a 350 sbc from a 76 camaro) and cant seem to get the ignition system working. I have an aftermarket starter with 3 posts on the solenoid (1 large one close to the starter, one large one on the outside, and one small one on the outside almost in the middle). As far as the key/ignition, there are 3 posts (bat, ign, sol), the fuse block has 4 fuses. If somebody could help me with the order in which to connect the wires, it'd be great. For the starter, i have 1 wire from the ign, one from the alt, one from the batt, one from the fuse block (ground...?) and one from the ballast. Any help would be appreciated, as i need to have the problem resolved. Thanks.
