Guest Anonymous Posted November 12, 2002 Share Posted November 12, 2002 I inherited a 280Z a few years ago and poking around with it now. It is a 75 280Z with a newer motor. I gather from the book (Chiltons) that the motor is a 79-83. I have no spark and someone before me was working on it and had cut all the wires at the resistor/coil and attempted to rewire. - There is 2-BLK w/BLK wires. A BLK b/BLK and a BLUE at the resistor/coil and a Green, Red, and BRN to the distributor. I don't know where any of these connect to. The book is very vague. Please help I have spent countless hours trying to figure this out. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted November 15, 2002 Share Posted November 15, 2002 Are you sure you have an IC electronic ignition unit? I tried for about an hour to find out why I didn't have a spark. and Found that someone took my ignition unit. (little black box attached to the distributor) If this is the case then look at the HEI ignition module thingie for about $30 as teh OEM ones run at about $140 here is the site incase you need it (and for anyone else who needs it) http://dimequarterly.tierranet.com/articles/tech_hei.html Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted November 18, 2002 Share Posted November 18, 2002 Yes, I do have an IC unit on the side of the dist. It has two terminals on top of it. Quote Link to comment Share on other sites More sharing options...
