Red Hot exhaust header
#8 header tube gets red off idle under no load.It's a 283 w/mid 80's194[350]heads,performer
RPM intake 750 holley.I have corrected fuel delivery,dist.timing,made sure the valves aren't too tight,and made sure that there are no external vac leaks.Put a 600 holley on it got the same results.It seems as though its lean popping up off idle.Has new plugs,wires,cap,and rotor.have triple
checked firing order and timeing.It has little or no blowby[no pcv system].I suspect vac leak on under side of manifold scavenging crankcase.Am I over looking anything?Help! 240 Al
You are 100% sure that your fuel delivery is an easy 5-7 lbs at the carb? I know you say that you double checked the timing--have you read about ellobo's recent post about the same problem? It should be here in the top 10 posts---please read it since it may contain the information you need. Hope you can cure it; good luck!
Davy
