Dimensions of the GN motor and trans
Guys I am SERIOUSLY considering the GN powerplant for my buddies project 240sx. The jap spec 2.0 is cool but ive never seen a gn motor in one.
I need weights on the trans and motor, dimensions to see if it will fit and any other relavant information that will help me ensure that this will fit in the engine bay with the auto tranny behind it.
Here is what I came up with. The measurements I can vouch for since I did them myself. The weights are from info in response to a post on the Buick forum.
Engine
Height - 28.25. This is from the bottom of the pan to the top of the TB
Width - 24.5. This from the outside edges of the headers
Length - 23.25. This is from the back of the block to the front of the pulley.
I did not use the published V-6 dimensions because I though those of a fully dressed turbo engine was more useful.
The published weight of a Buick V-6 is 375#. Add another 50# for turbo, alt, etc and the weight is about the same as a L6. The tranny weighs 135# and the stock 12" converter is about 40#.
BTW, aluminum heads cut 60# and a 9" converter cuts 15# icon_biggrin.gificon_biggrin.gif
HTH.
