Guest Anonymous Posted February 5, 2002 Share Posted February 5, 2002 Has anyone considered this engine. Like the Ford Thunderbirds from the early 90s. I think its a 4.3??L Supercharged and Intercooled V6. It makes around 220HP and 300lb ft of torque at 2K RPM i think. Thats pretty good. And with a smaller SC pully(more boost) and some other modifications, i bet this engine could really make alot of power. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted February 5, 2002 Share Posted February 5, 2002 Pretty sure that it is only a 3.8 cause a 4.3 is a Chevy V6. Sweet motors though. A friend had one in highschool and that thing hauled ass. Quote Link to comment Share on other sites More sharing options...
Kennysgreen280zt Posted February 6, 2002 Share Posted February 6, 2002 I think they are accually 245 hp , my uncle has had two of them. I think the motor may be too wide to go into a Z but I guess you can make anything fit , and it is a 3.8L . laterz ~Kenny Quote Link to comment Share on other sites More sharing options...
BLKMGK Posted February 6, 2002 Share Posted February 6, 2002 This has come up before. I said it then, I'll say it again - I wouldn't do it. I've seen a few of them that really held together but I've also seen at least 4 of them in my friend's shop with BAD head gasket issues and at least one of them with trashed pistons. These were cars that weren't hopped up - simply driven stock Overheat one of these puppies and it's toruble. There are better motors out there although if th eprice were "right" then I might consider one but..... Quote Link to comment Share on other sites More sharing options...
Guest Drewz Posted February 7, 2002 Share Posted February 7, 2002 I had six years in at my last shop and did 4 sets and 2 of them twice. If you EVER get it a little warm you are doing the heads. They were good but longevity wise they were weak as hell. Lots of stories about them and they are mostly true IMO! Quote Link to comment Share on other sites More sharing options...
randy 77zt Posted February 16, 2002 Share Posted February 16, 2002 i am a ford dealer tech-these things didnt work cause oem radiator was made smaller to put intercooler beside it.the engine weight is light because block is small and heads were aluminum.if you put some kind of good head gaskit on it and a stud kit for the heads plus made sure it ran cool it should be okay.a t5 trans will bolt on .oem 5 speed was made by mazda and has a huge ratio spread for a 3.08 rear.engine makes lots of torque but doesnt like to rev much past 5500 rpm.same engine as many other fords-wind stars.mustangs,tbirds,taurus Quote Link to comment Share on other sites More sharing options...
