Turbo-six Posted January 24, 2020 Share Posted January 24, 2020 (edited) I am working to clean up some wiring on my car, it's an s30 with l28et swap and Ford edis, Chrysler coil pack etc. It was setup by a previous owner and ran quite nicely, but the wiring was a bit messy. I am trying to wire back the Ford edis, based on the wiring diagram common here, there is a resistor 25uf placed on the EDIS power supply that is grounded. My car has resistors wired in to the 3 coil supplies, circled in blue in the attached Pic. My assumption are these are serving the same purpose as the 25uf in the normal diagram? On my car, the ends are tied together and attached to a single blue wire that I would assume needs to be grounded. In my haste I cut this wire without documenting where it went. The power supply #4 on the plug in my car does not have a 25uf wired in like the diagram. The engine is controlled by ms2 3.57 Thanks for any guidance. Edited January 24, 2020 by Turbo-six Quote Link to comment Share on other sites More sharing options...
