Toyota Turbo 7M-GTE engine swap
Guest 327zxer
  • 1 month later...
cheap 7m engines usually equal a blown head gasket, you want to stay away from that. The 7m is a very good engine usually good for about 700hp.
Guest jewishjalopi
being a supra freak myself, i dont reccomend putting a 7m in a z. I'd go with the 1jz-gte. much more potential with that motor, and you wont run into a lot of the problems that all the 7m supra guys face. in controdiction to someones post, the 1jz's IC is slightly larger than the 7m.
im not pulling the 1jz out of my 90 to put in the Z, the 7m will work fine because at 350rwhp your right at the 7ms efficiency range, the only reason its not so fast in the mk3 supra is the damn wieght, not to mention the only thing the mk3 suspension is good for is cruising at highway speed. at 350rwhp the 7m can be beaten on daily, and in 2300 lbs of car.. it will move pretty damn fast.
