Guest Anonymous Posted January 31, 2003 Share Posted January 31, 2003 i am trying to decide whether to buy a vg30dett or rb25det which has better potential power?,also does anyone know the stock boost limits of each engine. thanks for the input again guys Quote Link to comment Share on other sites More sharing options...
Guest eric-z Posted January 31, 2003 Share Posted January 31, 2003 well, if your in the US I think most people would probably tell you to go vg30dett becuase of the availability of parts. of coarse the RB25det is a very cool engine. eric Quote Link to comment Share on other sites More sharing options...
Guest eric-z Posted January 31, 2003 Share Posted January 31, 2003 if you feel like reading some, check out "Pro Drag 240Z for Import racing. Which engine?", they talk about the differences in the RB and VG a little. Quote Link to comment Share on other sites More sharing options...
Guest zline Posted February 1, 2003 Share Posted February 1, 2003 here is the quick and easy answer 1. if you're rich...know enough about fabrication to fit an engine into a bay other than the stock car which the engine came from and barely fit in get a VG30 2. if you plan to make less than 800 hp wanna do it relativly easy then get an RB25 you need 200ZR mounts oil pan sump and pickup GTSt transmission shave the ears off the tranny tunnel make a tranny tranny mount that attatches to the floorpan and wire it up and you're good to go.. powerpotential is almos tequal but if youre after a 1000 hp torque monster... 500cc will go a long way but like isaid sub 800 hp....its jus tnot worth the time and effort for a VG30 engine... Quote Link to comment Share on other sites More sharing options...
