Guest Anonymous Posted May 15, 2001 Share Posted May 15, 2001 Just have some questions - Wanting to know about this motor swap. Is it hard or easy? The motor and tranny drop in? Can you use the whole drive train or not? How would it be verses a small block Z? I have access to the whole 82Z. Or would it be easier to buy a small block V8 and to get all the conversions for that set-up? Any other info would be helpful! Quote Link to comment Share on other sites More sharing options...
Drax240z Posted May 15, 2001 Share Posted May 15, 2001 Tony, check out my website listed in my signature, it should get you started. There are also a few links at the end of the turbo buildup tech article to other turbo Z sites, prepare for a bit of reading. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 15, 2001 Share Posted May 15, 2001 thanks i will check it out!!!!! Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 17, 2001 Share Posted May 17, 2001 tony the junkyards in your area are just filled with z`s . so locating a turbo motor shouldn`t be a problem, while your at it you should grab the wiring harness. Quote Link to comment Share on other sites More sharing options...
