Spacer to add external wastegate....
After digging for info on adding an external wastegate for some time, I have decided the best way is to add a spacer between the manifold and the turbo. This is on a z31 with a VG30ET so clearance is already kinda tight. To fit a deltagate, it would need to be 2" thick. Can anyone think of a reason this wouldn't work other than clearance? Or do you know for sure it WON'T fit? The turbo will be using a T3 turbine housing.
