intake exhaust manifolds
i love maximum boost.
so i want to make custom intake/exhaust manifolds
intake
symmetrical design 65mm t.b. in center of plenum, 2 and 1/2 inch velocity stacks, welded to runners that get smaller toward combustion chamber with 5 degree mounted 470 injectors.
exhaust
each port has its own stainless steel pipe all welded to a 6 into 1 collected with small extension with HKS wastegate then turbo, still havent figured out size, oh yeah...can you guys help me out with this...turbine/compressor size
i have a 3 liter 280zx engine with JE pistons, stock crank/rods/cam
i want to run 15psi prehaps, .925 a/r, cermaic bearing, compressor flow approx 700-800cfm, 2 pressure ratio. any ideas?
-chase
