clint78z Posted June 14, 2001 Share Posted June 14, 2001 Well after trying to get Scotties wonderful mandrel pipe to fit on my 78z, it just wouldn't clear . So I decided to do a temporary fix with muffler elbows and pipe. I was able to get the pipe in the same place as Scotties old setup and clear the distributor. I also made up a spacer and made the stock fan fit with the shroud as well. Now instead of going with silicone elbows which are $$, I used rubber plumbing elbows. The cool thing about these is the pipe actually butts up against the elbow to further reduce chance of leaks and blow offs. I am a bit worried that the one on the turbo won't take the heat but we will see. I plan to make some drawings for others after I get the car going. Hopefulley it will be soon considering my busy schedule. Quote Link to comment Share on other sites More sharing options...
Scottie-GNZ Posted June 15, 2001 Share Posted June 15, 2001 Too bad. That is the problem with trying to duplicate certain items from one car for another with the various models. Did you ever hear from Melodie? I referred her to you about the NPR plumbing. Quote Link to comment Share on other sites More sharing options...
clint78z Posted June 15, 2001 Author Share Posted June 15, 2001 Yes it is too bad it wouldn't clear, however you were very clear in saying there could be some snags. I appreciate the other pipes though , definately a fine job. I talked to Melodie, I am going to doing some measuring for her on Sunday. I will more than likely do some AutoCad drawings up since that's what I do. Hopefulley I can lay out the entire package, for a 280z with A/C. Been a busy bee lately !! Hows the new intercooler working?? I think the NPR will be more than I will ever need. Quote Link to comment Share on other sites More sharing options...
Guest Tom Scala Posted June 15, 2001 Share Posted June 15, 2001 Clint,will these pipes allow the air cleaner to be mounted in front of the radiator & ac condensor? Are they 2" or 2.25"? Quote Link to comment Share on other sites More sharing options...
clint78z Posted June 15, 2001 Author Share Posted June 15, 2001 There is no room for the aircleaner to mount in front with a 280z, the bumper shocks get in the way. The air cleaner is direct mounted to the turbo, and pretty much sits on top of the A/C pump. Quote Link to comment Share on other sites More sharing options...
