Guest Anonymous Posted July 6, 2001 Share Posted July 6, 2001 I was considering building up a L28 Turbo motor. I see many of you are using SDS. I would prefer using the stock ECU to save money and to stay stock. What are the limitations to using the stock ECU? Jim Wolf suggested using a remapped "88-89" ECU with a Ford flow meter and larger fuel injectors. The cost of the remapped ECU from Jim Wolf is around $700. For that price I would probably just go with the SDS but like I said I would like to stay stock to save money. Any suggestions? Quote Link to comment Share on other sites More sharing options...
Drax240z Posted July 6, 2001 Share Posted July 6, 2001 Bah, stay away from Jim Wolf. For $700US you can have an SDS, and not have to get a reprogrammed ECU each and everytime you modify things. Ian L at zcar.com has run some pretty impressive numbers with his stock computered 3.1L turbo. Check it out. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted July 6, 2001 Share Posted July 6, 2001 Thank you for the response, I'll check Ian's site out. Quote Link to comment Share on other sites More sharing options...
