Power brakes and Turbo's...
Oh Turbo Guru's... I just was wondering how the power brakes work when boost is introduced instead of vacuum? I would assume theres a check valve or something but does your power brake still work ok if you are say heel and toeing and still have the engine reving a bit while applying brakes? Not an issue for me (now anyway icon_wink.gif) but was something I wondered about.
Regards,
Lone
Yes, they still work just fine. The check valve keps any boost from getting into the booster, so it's pretty much the same as n/a.
Actually, since the cam profiles are generally more conservative for a turbo, they usually have very good off-boost vacuum, so the brake performance does not suffer like it does with a long duration cam on a n/a car.
