turbo or supercharging
is it possible for an engine to actually perform worse in some casses if it was designed for naturaly aspired high performance and adding a turbo or supercharger? or is forced induction an all round good thing? just something ive been wondering about.
If an engine has a normal compression ratio of 10:1, then supercharging it or even turbo charging it is not a god idea without lowering the compression ratio first by replacing the pistons. Why? Because with forced induction, the compression ratio goes way up beyond 10:1 and you then run into all kinds of problems...
Davy
