Flak Posted January 28, 2023 Share Posted January 28, 2023 Good news, thanks to everyone here (especially NewZed) I got my engine to start. That led to me figuring out I needed new injectors and a radiator. Fast forward to today, injectors and radiator are installed, but my fuel pump and turn signals/hazards don't work now. What happens is, the fuel pump will run every once in awhile, then when I try a turn signal, it all just shuts off. Then the pump won't run and the pump relay doesn't click anymore when key is in on position. My turn signals/hazards don't seem to work on their own anymore either. I thought it was a battery charge/load issue, but I'm at 12.77v. I also rechecked all the engine grounds, and they all seemed fine, but I redid them anyway. My fuses are all good, and my fusible links are good too. The EFI fusible link has 12v. The fuel pump also runs when I power it directly. I'm thinking it still might be a ground issue? Maybe my fuel pump relay itself? Quote Link to comment Share on other sites More sharing options...
